โApr-08-2015 05:37 PM
โApr-09-2015 06:56 PM
โApr-09-2015 06:33 PM
โApr-09-2015 12:46 AM
BFL13 wrote:
... I asked why they had all these combined LP and CO detectors for sale, and where should they go? He shrugged, and said personally, he would have two different ones so the LP could be at floor level and the CO higher.
โApr-08-2015 09:03 PM
BFL13 wrote:
I asked at my usual RV shop what level the CO detector should be at and he thought up high, so I asked why they had all these combined LP and CO detectors for sale, and where should they go? He shrugged, and said personally, he would have two different ones so the LP could be at floor level and the CO higher. I have no clue what is the correct answer on that, but that is what we now have. The previous CO up high and the new LP alarm down low.
โApr-08-2015 08:57 PM
401nailhead wrote:
ok, this is a lot for me to ask, but I know some folks will be there for me, as time permits. We bought the 1996 Coachmen RV van two weeks ago in a somewhat competitive as-is/great price rush, so I knew we would have a few repairs and upgrades to consider.
The 19 year old Coachmen Chevy van is new to us. I have at least some repair sense, having old cars for many years, but RVs and their accessories and appliances are new to us.
Here are the things I am working on; any advice will be appreciated; thanks in advance:
-older vent fan on roof, doesn't work, doesn't look that great, probably needs re-sealed; I just went ahead and purchased the standard fantastic-fan, I'll figure out the installation from online info and videos. Curious if this has its own 12v fuse? The old fan likely had a fuse. Easy test would be to ground the power wire for a half second and see if a fuse pops. Don't leave it grounded long though in case it's not fused.
-carbon monoxide and propane sensors (long, narrow individual styles mounted over and under each other) - look original - were disconnected. I connected them today, both go on, one tests well, other questionable on test (no alarm). Online info says replace after 5 years. These are likely as old as the van. They are expensive I see, but life is precious. Any confirmation that it is time to replace? run, don't walk to buy replacements? They should both be replaced.
-trying to figure why the gas water heater seems to heat whenever the coach power is on, whether or not the heater switch is on - could this be a broken switch, always on (even though it is a gas heater)? Does it decide on its own to ignite? Today I was not sure it turned itself on, but previous says I think it did.Sorry I would be guessing on this.
-3 way refrigerator trips the breaker within about 60 seconds or less every time on 120 power when plugged in, but works fine long term on 12V when plugged in or van running. Have not tested on gas yet, but 120 power trips the breaker again and again. Probably a bad ac heater, I don't know if they are repairable but I would see if I could figure it out if it was mine.
-microwave runs 3 to 5 seconds then stops. On low power it ran 8 seconds maybe. It is not tripping a breaker, just stops running (and clock starts flashing as if power went out). I thought it was tripping breaker at first, but now realize it is just stopping, and I just need to re-set clock. I assume I need a microwave repair, or replacement, but want to figure out which. Nothing suspected in coach, or breaker box (I don't think?). well it's either the microwave or the wiring. Can you find the microwave plug (look in the cabinets next to it), unplug it and plug it into a heavy duty extension cord to your house. Now see how it works.
-last item is just general water-proofing, leak sealing. I figure, just look for moisture or wetness after rain, remove old sealant as needed, use new sealant as needed. reseal anything that looks cracked or is lifting off the surface.
thanks again for any advice, sorry to have the long list, but figured I would throw it all on the table.
God Bless America, the open road, and the freedom of RV's!
โApr-08-2015 07:55 PM
โApr-08-2015 07:11 PM
โApr-08-2015 07:07 PM
โApr-08-2015 06:13 PM
โApr-08-2015 06:07 PM
โApr-08-2015 05:41 PM
