spat61's avatar
spat61
Smoked at the Pedestal Need Help (long post)
I plugged into 50 Amp at a reputable CG. After dinner we took the dog for a walk. When we returned the lights were out and I had a sick feeling that my entire unit was smoked. After a fast check I quickly noted the converter, refer, 37" TV, and the fireplace were all smoked. I asked the CG manager to check his pedastal. Needless to say no problem with it. My dilema is a question regarding the converter. A fellow camper said because the converter is not working, it's probably causing the display to loose 12V to run the circuit to turn the display on. I checked the two fuses in the refer circuit card. Both fuses are good. I have a 55amp chinese converter and a Dometic refer in a two yesr old Forest River fiver. Can anyone out there tell me what direction to take to get the converter and refer working? I'm not close to any dealers, mobile service or a Camping World. Thank you.
Steve
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
