74williammorris
Jan 11, 2018Explorer
Strange problem with My Kwikee Electric Steps
Until yesterday my Kwikee electric steps worked exactly as they were supposed to. Then for some unknown reason the steps stoped working when the motor home ignition is turned off but the steps work correctly when the ignition is turned on.
Can anyone tell me what to check?
❚ Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
- Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM TECHNICAL SUPPORT
