โJun-17-2019 07:15 PM
โJun-18-2019 11:44 PM
Veebyes wrote:
Getting behind the reset cover is the only thing not done. Removed the screws but cover did not come off easy so left it. Will do again & be more aggressive this time removing cover now that I have an idea of what is behind it.
As luck has it, a guy with a Mobile Suite, same water heater as mine, has just rolled in. Also has water heater problems. 120V side. Burnt wire behind reset buttons in his. Will try to get back to mine later today.
Thanks for responses. Always good to check with the assembled multitude.
โJun-18-2019 07:24 AM
โJun-18-2019 03:18 AM
โJun-17-2019 11:06 PM
โJun-17-2019 08:53 PM
MFL wrote:
I'm thinking my 6 gal has two resets, one elec, one gas, under the black covers, behind burner tube. The 10 gal likely same set up. Igniter should click, even though it fails to light.
Jerry
โJun-17-2019 07:28 PM
