Darklock
Nov 15, 2021Explorer
Tub Drain
This afternoon I decided to do a quick bit of maintenance. Check the water heater anode rod and flush the tank. One thing lead to another. Why not sanitize the freshwater tank while I'm at it?
To flush the system, I used the bathtub faucet. I have always had a little water on the floor after showering, figured it was just water getting by the curtain. But while running the tub today, I found the same small puddle.
Some investigation revealed that the tub leaks around the drain. This is because the P-trap is directly touching the floor. Stepping in the tub caused enough flex to put upward pressure on the drain basket and a breaking of the seal of plumbers putty.
I've got about a ten inch by ten inch hole to work with. I can either see what I'm looking at or have an arm in there working. Not both. Not sure how I am going to get a second arm in there to hold two wrenches to work with in order to re-puddy the drain.
After this, I need to figure some bracing to stop any of the flex, or the problem will continue. There may even by some room for this bracing to fit. Fingers crossed.
