d1h
Jul 20, 2023Nomad III
Grit dog wrote:mkirsch wrote:Grit dog wrote:
God advice received, albeit with zero other helpful input or response from the OP.
Barring the extreme weight or vehicle condition scenarios that many on here like to put forth to “help” those with less than common sense, yes a 2018 6.2 GM half ton will pull that trailer smartly, safely and capably in any reasonable configuration/scenario.
Common sense isn't common.
Agree wholeheartedly......
What scares the hell out of me is wondering when I’ll get to this state of being and praying that I’ll notice it as not to embarrass myself regularly….
Good advice received, albeit with zero other helpful input or response from the OP.
blt2ski wrote:
That will be closer to 1000 lbs of HW loaded.
Payload of burb? How many occupants and weights? My family of 6 with 4 adult sized teens was 1200-1300 lbs, plus 1000 lbs of hitch.....that's at the limit of most GM 15 series trucks, be it a burb, or my ext cab pickup. If it's just 2 adults, doable payload wise.
The 6.2l has upwards of a 12-14k tow rating iirc. Power is not the issue. It will be lack of payload.
Marty
