- ShinerBockExplorerFake news? I watched them tow the Ford another three times and not once did Kent say "out of control". In fact, the only time he even said control was at 6:36 of the video when he stated " As much as we like light weight for a lot of reasons, fuel mileage and all that, it doesn't help your control" He never said "out of control".
Porpoising has more to do with the suspension than the weight of the vehicle.
Suspension Enhancement To Reduce Porpoising When Towing 30 Ft Travel Trailer w/ 2015 GMC 1500
What Stops Porpoising on Tow Vehicle that is Using Weight Distribution with Trailer
Notice both of those trucks were GM 1500's with the 6.2L that are much heavier than the Ford in the video. Adding suspension upgrades or selecting a vehicle with a stronger suspension (F150 HD or higher) would eliminate or substantially reduce porpoising. - RobertRyanExplorer
carringb wrote:
ShinerBock wrote:
I never heard them say that they felt it was "out of control" either.... :?
In fact, they even stated at the very end that the F150 was fine for that amount of weight for people who don't tow it very often.
Well clearly all our trucks are inferior because all of the highways in Australia are steeper, longer, and higher. And they must drive much faster than the measly 75 MPH speed limit in Colorado.
Kent Sundling said it felt out of control and porposing., teeter totting in his words. Nathan mentioned the ride was not very nice and the Pickup bounced around a lot..There are steeper gradients here and no doubt in the US. No surprise the Nissan felt better with a base weight of 6200lbs versus 49170lbs. Lack of engine braking from the Fords turbocharged 3.5 would contribute to the excessive braking compared to the Titan. - LessmoreExplorer IIDecades ago, we used our '76 Impala to tow light trailers. It was the last of the big, GM sedans. It was rear wheel drive, full frame, etc...old fashioned platform for a sedan. The rear springs were tired, when we started towing, again light trailers.
The car's rear squatted, it felt a bit unstable. I took it to a shop that specialized in suspension work for mostly highway tractors, gravel dump trucks, etc...they worked on smaller vehicles too and really knew their stuff.
They installed some heavy duty MOOG springs in the Impala and what a difference in towing, handling solo, etc. Ride was more firm, but not bad and given enough road width that Chevy could really hustle through the corners with a load attached. No sway, no bottoming, no instability.
I know it was just a car, but I can well understand the difference the installation of the proper, heavy duty springs can affect the load capacity, trailer hauling ability...positively...of any vehicle.
It would be interesting to see TFL guys (I'm a big fan of them) tow test an F 150 HD. - ShinerBockExplorer
demiles wrote:
They made it clear that the F150 suspension had issues handling that much weight even when it was setup using a scale to assure proper loading. So now consider the average Joe connecting his travel trailer which may be less overall weight but just as much tongue weight. They commented how tight they had to make the WD bars and Joe has to do the same. The outcome for Joe just might be worse than than what they experienced with controlled loading. Visit the f150 forums and you’ll see that a lot people complain about instability of some type with this truck. They’ll spend thousands in replacing tires, shocks, install airbags/Timbrens, and sway bars they to get a decent ride. I wanted to like this truck for towing but those complaints really turned me off from buying it.
I think this is most regular half tons in general or with any vehicle the closer you get to its limitations. What most people don't know is that there are five different leaf springs for the F150 ranging from a 3,500 lbs capacity to a 4,800 lb capacity. Most trucks on the lot are on the lower end of those ratings and you have to special order the $1,600 HD package like I did to get the 4,800 lb ratings.
When I had my 2012 Crew Cab F150HD, I also had a 2012 F150 Super Cab company sales truck that I towed with at least a few times a month. Believe me, there is a night and day difference in how the regular suspension F150 and the HD suspension F150 handled the weight. I would put an F150 HD up against a Titan XD and its 4,900 rear axle rating any day of the week and twice on Sundays. A regular F150...... not so much - demilesExplorerThey made it clear that the F150 suspension had issues handling that much weight even when it was setup using a scale to assure proper loading. So now consider the average Joe connecting his travel trailer which may be less overall weight but just as much tongue weight. They commented how tight they had to make the WD bars and Joe has to do the same. The outcome for Joe just might be worse than than what they experienced with controlled loading. Visit the f150 forums and you’ll see that a lot people complain about instability of some type with this truck. They’ll spend thousands in replacing tires, shocks, install airbags/Timbrens, and sway bars they to get a decent ride. I wanted to like this truck for towing but those complaints really turned me off from buying it.
- carringbExplorer
Well clearly all our trucks are inferior because all of the highways in Australia are steeper, longer, and higher. And they must drive much faster than the measly 75 MPH speed limit in Colorado. - ShinerBockExplorer
Lessmore wrote:
I watched the video test a couple of days ago. My impression was that the testers didn't say or imply that the the Ford ".. was out of control..." as you have indicated. My view was that they felt that the Nissan exhibited more stability in it's ability to control the trailer movement...as compared to the F 150.
Using the phrase 'out of control' paints a picture of a vehicle that is completely unstable .
In fact, they even stated at the very end that the F150 was fine for that amount of weight for people who don't tow it very often. - LessmoreExplorer II
RobertRyan wrote:
carringb wrote:
RobertRyan wrote:
Maybe. Ford says the Pickup passes the J2807 standard for towing that weight,Going By the results either the standard is not representative or Ford is making a bad call on it's compliance.
Having to brake 9 times compared to twice on the Titan XD on a fairly moderate gradient and feeling you had little control, suggests something is pretty wrong.
It towed it, didn't it? J2807 has no requirements for engine braking. They did not overheat their brakes or lose any braking performance, so I'd say it worked as intended. I'm not saying engine braking only isn't nice, but it certainly isn't necessary, especially for somebody who buys a truck for only occasional towing.
Just 12 years ago, a stock Cummins diesel would have required the service brakes even more.
Fellows who did it felt it was out of control. Luckily it was on a modest gradiant
Using the phrase 'out of control' paints a picture of a vehicle that is completely unstable . - RobertRyanExplorer
Fellows who did it felt it was out of control. Luckily it was on a modest gradiant - TurnThePageExplorerAgreed. They demonstrated that Ecoboost can easily manage the load, but the truck struggled some. A person would be foolish to choose that F150 for that kind of duty on a regular basis. I would like to have seen how the HD F150 handled it.
Nissan appears to have a winner with their gas XD.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 18, 2025
