sidney's avatar
sidney
DRW Stability
Been reading the SRW vs DRW threads...
I have never towed with a DRW and I'm curious what everyone means by "stability". Can you describe what you're experiencing that feels more stable.
To say the DRW is more stable vs towing the same 5er with a SRW would inherently indicate you experienced some type of instability towing with a SRW.
If you are significantly exceeding the GVWR towing with a SRW I can understand how the DRW towing the same 5er would be more stable.
However if you are well within all towing specs towing with a SRW... what are the advantages of switching to a DRW?
