โApr-25-2016 10:18 AM
โApr-26-2016 05:07 AM
โApr-25-2016 08:56 PM
Paul Clancy wrote:
I had one with a slow leak. Pulled out the fill valve from bumper. Removed the red hose. Cut the end 90deg flat. Cleaned inside the valve and reinserted the hose ( pushed in good). Leak fixed. An installer on this board said the actual bags rarely fail - more often the fill valves.
โApr-25-2016 07:21 PM
โApr-25-2016 07:01 PM
Paul Clancy wrote:Thanks I will give it a try.
โApr-25-2016 06:58 PM
christopherglenn wrote:I found a 5 port tank on ebay for 35. with free shipping.
The 1/2 gallon tank is actually a good idea. They are usually used as ping tanks, when you hit a bump the pressure in the bag spikes, the tank gives it a place to go so the ride is not as harsh. I am going to put one on each side when I get the bags on my new truck.
โApr-25-2016 05:46 PM
โApr-25-2016 12:57 PM
โApr-25-2016 12:54 PM
โApr-25-2016 12:24 PM
fj12ryder wrote:Takes about a week to go down. There is no air volume in just the lines, a small tank might keep it for a month.
How small of a leak is it? Loses how many psi over what period of time? What purpose would the 1/2 gallon air reservoir serve? Just as a bandaid?
โApr-25-2016 11:59 AM
