- obgrahamExplorerAviation intercom and a couple of headsets. There are portable battery operated ones.
- 45RicochetExplorer
charlie good time wrote:
Being hard of hearing an with wife with weak yoice any recomendation for electronic help while traveling in diesel pusher.
Say what? Your DP is loud? That don't make sense as the engine is about 30' behind you. We don't hear much engine noise whatsoever, in fact I can't hear the engine brake anything like our previous Ram 3500 with the same Jacobs exhaust brake with the 5.9L.
Could it be your front mounted Onan Generator making the noise? I know our screen door makes a lot of racket that I need to fix. Best advice I can give is the walkie talkie route for a cheap fix. Most have belt loop connectors and a ear plug. In the mean time, watch for finger to know you passed the correct off ramp :W - GeezeExplorer
the_happiestcamper wrote:
I would enjoy the ride :D
X2:B - the_happiestcamExplorerI would enjoy the ride :D
- TakingThe5thExplorerI have a set of Starkey Halo hearing aids and an iPhone and they are coupled together via Bluetooth. I also have some Starkey software that allows my iPhone to work as a microphone to the hearing aids. So my wife can either call me on her cellphone or I can simply give her my iPhone to use as a microphone and the range would probably be 50 feet or so.
That said - we still use our adult Motorola walkie talkies because change is hard. - ramgunnerExplorerJust be aware that anytime you are using a two-way radio for this sort of thing, anything you say can and will be transmitted to others.
> Be very careful about what you say
> Use the LOWEST power output available on the radio.
> If you look at one using GMRS frequencies/power, make sure you have a license to use it. - kmbeltExplorerOne of these Motorola radio sets would work.
They have headsets and can be setup for voice activation in which you don't have to key the microphone. They just can sense when you start talking and do it automatically.
There are many brands that exist that do the same thing. can be had for under $100 for a good set. - RedRocket204Explorer
BenK wrote:
There are intercom's for tow people on 'one' motorcycle, but they are made for
inside the helmut...maybe you could either find them with head sets or install
them on a set of stereo head sets or some such
Sena is a company that makes those for inside helmets... I have one of their devices, SMH5, and it works well. Not sure if they make a headset option. - BenKExplorerThere are intercom's for tow people on 'one' motorcycle, but they are made for
them on a set of stereo head sets or some such - TravlingmanExplorer II
I wish I could help, but I have the exact opposite problem. :B
About Travel Trailer Group
44,026 PostsLatest Activity: Feb 24, 2025
