Feb-01-2016 11:23 PM
Feb-05-2016 11:18 AM
If you are fine with lower performance standards just so you can say your favorite make can tow 30k at a dismal 35 mph then fine. I would rather the standards be raised so it would be rated to tow a lower number at a higher speed closer to the actual speed limit.
Feb-05-2016 10:35 AM
Bionic Man wrote:ShinerBock wrote:
That was actually the 2012 numbers, but as I said above they specifically "upgraded" and configured their truck to get high J807 numbers due to the lower standards and loopholes that it does not test. Basically overnight a 4.10 geared Ram 3500 with a 35 hp and 50 lb-ft of torque increase along with a slightly shorter 1-3rd gearing(4th is the same and 5-6th are taller) gave it enough of a performance boost to tow 30k the same as the previous model would tow 22k. Riiiggghhhttt....
Just so you don't think that I am just picking on Ram, I don't think that just a 40 hp and 60 lb-ft increase would allow the F450 to tow 31k with the same performance as it did with towing the 24k it was rated for the previous year either.
I can't speak to the Ford, but you are missing a LOT of the upgrades to RAM between 2012 and 2013. It is a whole new truck.
Feb-05-2016 09:27 AM
Cummins12V98 wrote:
"Then there is the Ram 3500. Before Ram made all their "upgrades" specifically for the J2807 the most a 3500 was rated tow was 22.7k lbs. Then afterwards it was 30k.
There is an incredible difference between my 2011 Dually and my current 15 Dually. RAM specifically has not just made up numbers. They LOOKED the same but that is the only similarity.
Feb-05-2016 09:16 AM
Feb-05-2016 08:19 AM
Feb-05-2016 07:54 AM
Feb-05-2016 05:54 AM
Huntindog wrote:
I like to tow at or slightly above the posted speed limit. Therefore I think your idea of a "test" is inadequete.:B
Give it a rest.
There is no such thing as a "perfect" test in everyones eyes.
We could go back to when there were no standards, and they could just pull numbers out of a hat.
Feb-05-2016 01:41 AM
Feb-05-2016 12:03 AM
ShinerBock wrote:mileshuff wrote:ShinerBock wrote:
Now which is more reasonable for this 350/3500 truck to be rated to tow...30k or 23k? Again, keep in mind that the truck will not be test going down the hill towing that weight. Funny thing is, most of these 350/3500 DRW trucks were rated at around 23k before J2807 came out.
Although, I would have to ask how many typical people tow 30k in their 350/3500 or how many people hear tow 12k in their 150/1500 trucks? That is what these trucks are J2807 rated for since the standard is so low at 40 mph for SRW and 35 mph for DRW.
The test itself makes little difference if all trucks perform the same tests. Now we can compare. It doesn't matter if the tests represent what YOU will need. I can now compare one truck with another. Its not difficult to derive expected results for your particular needs.
I can pull my 5'er up highway 68 at 50mph. Mine is rather lite at 10K. I can downshift and pull at 65mph easily if I want to redline the engine the entire way. Would that be an accurate test? Again, it makes little difference as long as the conditions are the same for which to compare.
Most here realize that tow ratings are maximums with expected low speeds. Car manufactures also give 0-60mph times. How many people actually do 0-60mph starts on a typical basis? Very few but the times do give a good comparison between vehicles.
Then why are you for such high 30k tow ratings if you or the "typical person" will never even tow that much?
Also, I am not against a standardized tests to make sure everyone is comparing apples to apples. I just think the standards on that test should be raised so that the ratings from the tests are more inline with reality and safer towing. I don't see why one would be against having lower tow ratings to a more reasonable and safer number. Are you seriously telling that you think that a DRW 7,500 lb regular cab 3500 should be rated to tow over 31K? Or that a half ton should be rated to tow over 12k? That is the ratings of trucks now due to the low standards of the J2807.
Feb-04-2016 07:27 PM
Feb-04-2016 07:14 PM
Feb-04-2016 06:58 PM
These are the two main reasons why I say raise the speed requirement which in turn would lower the tow ratings to a more reasonable number most pickup truck owners would tow with these trucks. Plus since the J2807 doesn't have a long distance down hill braking test I wouldn't mind seeing some lower towing numbers on these vehicles.
The gradeability test is done on highway 68 in AZ climbing from 550ft to 3500ft in 11 miles. It's a decent highway to use for such testing. Very few 2500/3500 trucks towing 25Klb+ rigs can sustain 55mph up this grade. Especially when its 115F! Making the test 55mph minimum isn't real world. I want tests that are inline with what the typical person would be experiencing.
Feb-04-2016 06:02 PM
Feb-04-2016 07:53 AM
rhagfo wrote:
I think they are still fighting server issues!
