- ScottGNomadThey better danged well be considering some kind of upgrade to more gears or the market is going to pass them by.
- wilber1ExplorerThe ZF 8 speed is a great transmission but I don't think there is a version that can handle the Cummins torque.
- ScottGNomad
There isn't right now but they could certainly engineer one. ZF is a very good transmission co! - Grit_dogNavigator^ZF already has one and it's not the 8HP variants in the rest of the Chrysler line up.
Correct, the 8hp is tapped out for duty behind 1000ft lbs.
Ram has already been testing it. Called the Powerline iirc.
It's "true medium duty" as someone on here used to profess all the time.
Our 07 will be old enough to drive itself by the time it comes out!
That's a long time for Ram to take to step up their tra mission game.... - Cummins12V98Explorer IIIMulti speeds did not do anything for the Ford n GM.
More reasons to keep my truck. - Grit_dogNavigatorI can see it now....the next AMZ OIL commercial.
Using Amzoil ATF is like adding 2 extra gears to my transmission! - ScottGNomadIMO it did a lot for the Ford. More OD means trucks can have lower gearing for pulling and higher gearing overall for empty running. Fords OD is arguabley a tripple OD and gets the RPM crazy low when empty. I have 6 gears and it would be awesome to have a couple more gears for empty freeway travel. It has the torque but not the gears. I can easily see how beneficial it would be to have even one more gear.
Hell yea! - Cummins12V98Explorer IIIFord did what it did because it simply had much more power and TQ.
- rhagfoExplorer III
While I agree that they need to update and get more gears, they did do better than the GM on the Ike.
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 20, 2025
