Old-Biscuit wrote:
City water inlet and black tank flush connection????
Shower drain 'P' trap?
Did not think of the city inlet, I will try to get some in that, or blow it out. No tank flush system on our small rig. I think I got enough in all the traps, but I may go dump some more just to be extra sure.
Go Dogs wrote:
Take batteries out of smoke detectors and leave the fridge/freezer cracked open!
We crack the fridge/freezer open after every trip. I am naughty, there was no battery in smoke detector, it trips EVERY time we use the furnace or stove, I really should install a better detector that doesn't nuisance trip all the time.
NanciL wrote:
Two things:
1. Did you run it through your shower. Then leave the shower hose hanging down
2. Did you put a bit in your city water inlet. There is a check valve in there and it will freeze and break if you didn't.
I usually use an eyedropper and squirt a bit in from the outside
Jack L
1 Yep I did, left it hanging.
2 see above.
remdog*1 wrote:
Don't forget outside shower. Remove any water filters
No outside shower, and no filters, but good tips to remember, next rig we get will have (or I will add) an outside shower.
Need-A-Vacation wrote:
...BUT, how much antifreeze did you use? You need to make sure you pushed all the water out the lines, and make sure there is enough antifreeze in the p-traps of the sinks and tub/shower as mentioned.
I used about a gallon, but I do have a pretty small RV, not a lot of pipe, only the shower, toilet, and kitchen sink.
gbopp wrote:
You may want to give your roof a quick check. Make sure there is no loose or missing caulk, damage, etc..
A very good tip, I am pretty good about checking my roof, I was just on it recently resealing the front and back seams with eternabond tape as an extra layer of protection, so I should be good for now, had I not just been up there this would have been a good time to do it though.
Dirtpig wrote:
pour some antifreeze into each sink drain & shower drain so it fills the P traps. Dont forget outside shower if u have one, often missed.
I did a video on how to winterize a while back. Here it is if you care to watch
Winterizing Video on Youtube
I am going to be dumping some more in the tanks after all the suggestions here.
Good video, I hadn't seen that one, but I did watch a few others before hand, so I had a pretty good idea what I was supposed to be doing. I just started this thread to double check my work :)
Thanks to everyone who replied, I really appreciate all the feedback and suggestions.
