Tequila
Jul 17, 2014Explorer
Yeah I would look for pre mid 2007 to avoid all the DPF stuff. Since I RV in Mexico a lot that is especially important as there is no ULSD yet. Be careful of the 2003, 2004 Duramax. Injectors are the big issue there and it.s $5500 to change them. The issue is not the injectors but fuel filtration. You need to put in a lift pump and double filtration like the FASS system to avoid that issue. A good idea with any diesel actually. A dually will give you much more stability. I would also look at GM or Dodge & avoid Ford unless you go older and get a 7.3 in good condition.
44,029 PostsLatest Activity: Jan 13, 2025
