Marathons, what to replace with
tealboy
My trailer tires are st175/80r/13 , load rated C, made by Goodyear/marathons. They appear to be in fine shape but they are old enough that I want to replace them with new tires. It appears Goodyear doesn’t make these and the new endurance are not made in this size.
Any suggestions on another brand? I would like to use my existing rims instead of buying new tires and rims. Also, I don’t have any spare room for a larger tire.
I know Tire topics get old, I’ve dont some searches but my size is less popular so less info on the forums.
15 REPLIES 15
Hannibal
My cousin runs bias ply tires on his 24' travel trailer. Following him up I-75 last week, I got a good example why. His left rear tire disintegrated while running 65mph. No damage done to the trailer. Chunks started flying and the tread rolled off into the median. One a previous trip a few years ago, he lost a radial and it even tore out the shelves under the sink with the steel belts slapping. I've noticed U-Haul has gone back to bias ply trailer tires as well.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
CharlesinGA
Carslile Radial Trail HD
https://www.carlislebrandtires.com/our-products/product-detail/radial-trail-hd
Haven't heard anyone complaining about them and a co-worker has had good luck with them so far on his Avion TT.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
MFL
Nomad II
Nomad II
Lwiddis wrote:
MFL, I’m running Providers, 14 inch, LR D. So far...4000 miles...so good.
My 2012 came with Provider tires when I purchased it new. Yup, I'm still running them, and they have been a great tire!
Jerry
shelbyfv
I've been happy with the Carlisle HDs mentioned above. If I had to replace them I would consider the new Goodyears because they are MUSA, though I understand that isn't an option for OP. As it is, I'll likely be too old to pull a trailer when these age out....
facory
Maxxis M8008. Travel proven for years. I never run anything but and have never had a problem.. I change them every 5 years.
2008 Cruiser RV Fun FinderXtra
Ford F150 Lariat 4x4 SuperCrew 5.4L 6.5' Bed 150" WB 3.73
Schwinn Mountain Bike
amxpress
I had the same size on our first Jayco. Went to a Maxxis 185 tire and they worked great. I have Maxxis on my Columbus fiver now. They are a proven trailer tire and have been around for some time.
Maxxis M8008 ST tirss
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
98coachman
drsteve wrote:
These are your size, and load range D.
Clicky
. X2 have this brand on my trailer and love them! Probably 10000 miles on them and they still look like new. I would buy them again in a heartbeat! Got a great deal on Amazon on them. Good luck,Bill
beemerphile1
dockmasterdave wrote:
Our TT came with the same size tires. Adding up the capacity of all 4 tires came to 100 lbs below the tt GVWR....
But doesn't the GVWR include the tongue weight? The tire (X2) rating needs to equal or exceed the axle rating.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
profdant139
Thanks for pointing that out, Sound Guy -- good catch!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
drsteve
Clicky
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
SoundGuy
profdant139 wrote:
So far, we really like our Goodyear Endurance tires. Made in the USA, higher speed and load ratings. We have over 10,000 miles on them so far. Expensive, though.
It would seem you didn't read the OP's post. :R
2012 Silverado 1500 Crew Cab
profdant139
About our trailer
Lwiddis
dockmasterdave
I switched (after a couple flats ) to Maxxis 8008. I went to the next size up, I think it was 185/13 and it increased my safety margin by about 600 lbs. They only offer 2 sizes in 13". Have about 5000 miles on them and so far so good.
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
