Matts6foot8's avatar
Matts6foot8
No floor joists in 2001 trail-lite 30' tt!
Recently aquired a 30' 2001 trail lite tt. Noticed right away the floor was weak through almost entire high traffic areas. Took off a few metal panels underneath and discovered they made these with no floor joists! Just 1/4" plywood panels sandwiched on 1-1/2 foam. Towards the rear the water,grey,and black tanks support the floor. Wich off course has weakened significantly over the years. My question is has anyone added floor joists from underneath? And as these trailers travel is flexibility required with the frame? Here's a pic of what I'm dealing with.
Btw I laid plywood on the ground to crawl around on so the image might look confusing.
