otrfun's avatar
otrfun
Feb 14, 2016
Payload: Ram 2500 Diesel vs. Ram 3500 Diesel
So much debate about the artificially low payload on the Ram 2500 diesels. That the low payload is only due to the 10,000 lb. GVWR. That the Ram 2500 diesel shares the same frame and drivetrain (differential, wheel bearings, etc.) as the Ram 3500 diesel (~11,700 lb. GVWR) which has approx. 1,700 lbs. more payload. The only difference between the two truck appears to be the rear suspension (Ram 2500's coil vs. the Ram 3500's leaf).
These numbers and differences aside, has anyone actually measured the total AVAILABLE suspension travel, empty vs. loaded to maximum payload, on these two trucks? IMO, these simple measurements would settle this whole debate once and for all.
For example, let's say, hypothetically, the Ram 2500 diesel has 5" of available rear suspension travel empty and only 2" remaining when loaded to maximum payload (~2200 lbs.). Again, hypothetically, let's say the Ram 3500 diesel has the same 5"/2" difference when loaded to its maximum payload of ~4000 lbs. If this was the case, then clearly there's more at play then some artificial GVWR.
But, then again, if the Ram 2500 diesel was loaded to the Ram 3500's maximum payload of 4000 lbs. (using the above scenario) and still had 2" of remaining suspension travel then it would seem the 10,000 lb. GVWR, could very well be "artificial".
Thoughts?
