CABigbird's avatar
CABigbird
Slide blows fuze
2017 Forest River Surveyor RKS251. This should be under warranty, but have to haul it 100 miles to repair. So, am searching for help with my problem. The slide (u booth) blows the fuse when being towed. It has happened three times just getting it home from the dealer. Each time the slide works good when parked. Either with the harness hooked to the tow vehicle or on 110v power, or on battery only. I retract the slide before leaving, and when we get to destination the slide fuse is blown and needs replacing. I can extend and retract the slide multiple times when parked, but towing it causes the fuse to blow. Can't find a schematic for our unit so have no idea about the wiring. I don't think there is any connection, but the LED awning lights would not work when we made our first stop. They were not checked during the walk thru because there was not enough room to deploy the awning. The fuse in the panel was not tripped, but found an inline fuse behind the lighted switch that was blown, a 3 amp one, replaced and all is well with the led lights. To me this sounds like a short or bad switch, but does not make sense. Wouldn't the slide switch have to be either in extend or retract position for the fuse to be blown? Thanks JH
