daily double wrote:
Has anybody had a solar installation on their rig recently? I'm camper shopping and wonder about the cost of aftermarket solar add-on
Lots of options.
www.amsolar.com is where I bought my solar.
I bought My Battleborn batteries and Victron DC to DC charger direct from Battleborn.
My Victron inverter was purchased from Northern Arizona Wind & Sun
Here's an overviewof the solar on my AF 811- StirCrazyModeratorI put mine on over the winter. for now I did a 325 watt split cell panel, and a renogy 40 amp mppt charge controler. the best thing you can do is find the biggest panel you can put on size wise. make sure you have room for two even. I made a carboard cut out and climbed up and layed it around to see if different size panels would fit and how they would fit.
do yourself a favor and go with a 24v panel and split cell if you can. way more efficient in early moreling or lower light levels. mine wanst prewires, so I ran the wires into the fridge vent on the roof then took off to the battery compartment from there. all togeather it was about 600Cdn for the panel, controler, mounting kit, wiring kit, new battery wires from the controler and so on. I know in the US stuff is a lot cheeper so I would expect you could di it for about 300.
Steve - Buzzcut1Nomad III did the DIY/ Camper was pre wired
Parts for 2 100 watt panels mounts wiring and controller was under $400. Time to install and have it up and running was under 3 hours with a buddy helping me get the panels up onto the roof. - JKJavelinExplorer IIIIt looks like many replies are DIYs, and it sounds like you are interested in having it done for you.
I had a complete turn-key system installed 18 months ago at a solar dealer in Quartzsite, AZ. It's 570 watts (tiltable) with 4 AGM 6-volt batteries, MPPT controller, and 2000 watt inverter.
$6400. Done in 8 hours.
JK - mbloofExplorer
adamis wrote:
Many people with more experience then myself for solar but I will throw in my two cents. Having a fiberglass camper, I was hesitant to add any more holes to the roof. I went with these thin film panels by Renogy on Amazon:
https://amz.run/4u4o
I ended up getting some double sided eternabond tape along with the regular onesided eternbond tape and taping the panels to the roof with the double sided tape in the center of the panel (to prevent negative pressure from pulling it off the roof) with regular tape around the edges. About thee years later and thousands of miles and they haven't budged an inch.
Some people on these forums might raise the issue of efficiency loss due to heat because of lack of air-flow and other reasons to go with the rigid and framed panels. While rigid panels generally are more efficient, drilling holes in your roof and adding a complicated mounting bracket system isn't my cup of tea. I will gladly accept losing a few watts to have a cleaner install. They also make these panels in 200W versions so if you have the space on the rough, you just tape the two down for 400w then run your wires. Nothing complicated and no holes to worry about.
Personally, I went with the stick on panels. Sure they are only 68W each, not made anymore and will likely never come off but they work for me. Installed in 2014:
Where I live most unimproved campsites and boondocking spots are closed off for the winter months leaving only private and state campgrounds as the only options. Both of these usually have at least power or full hookups.
I have a pet that I leave at home so that limits my trips to only a few nights at a time. This makes carrying enough AH storage and recharge ability for my meager power needs rather simple and easy.
YMMV.
- Mark0. - adamisNomad IIMany people with more experience then myself for solar but I will throw in my two cents. Having a fiberglass camper, I was hesitant to add any more holes to the roof. I went with these thin film panels by Renogy on Amazon:
Some people on these forums might raise the issue of efficiency loss due to heat because of lack of air-flow and other reasons to go with the rigid and framed panels. While rigid panels generally are more efficient, drilling holes in your roof and adding a complicated mounting bracket system isn't my cup of tea. I will gladly accept losing a few watts to have a cleaner install. They also make these panels in 200W versions so if you have the space on the rough, you just tape the two down for 400w then run your wires. Nothing complicated and no holes to worry about. - mbloofExplorerEasy as pie. Especially if your camper is "prewired" for solar.
Even a mere 100W in good sun can extend your camping trip.
Amazon is your friend. Checkout the pricing on 100w panels and then 10A MPPT charge controllers. Fairly inexpensive stuff.
Need/want more power? Have less sun? Add panels and higher amp charge controller and/or add more battery capacity.
Some folks add as many panels as they have room on the roof and others are happy with 2 or even 1 panel.
- Mark0. - naturistNomadSolar is great for everything except running the AC as long as it is sunny. The panels are the least expensive part of the system. I built a 400 watt system last year, $320 for panels, similar for 2000 watt PS inverter, ditto for an MPPT charge controller and another $550 for two 125 AH AGM batteries. You can do the math, but remember wires, fuses, screws, lag bolts, etc. aren’t free.
Yeah, I coulda bought a generator that would even run the AC for that. But solar will run silently for at least the next decade for no additional cost, no fuel, no maintenance, no spark plugs, and did I mention it’s SILENT.
Hope that helps. - HMS_BeagleExplorerIf the camper is pre-wired for solar the hard work is done. The arrays themselves are at most $2/watt, good mounts are $20-40 for each panel. I've found 200 watts to be more than enough for continuous living, in the sunny west. Not sunny or a lot of time in the shade, then more.
The controller is anywhere from $50 for a cheap one - not really the place you want to save money - to $200 for one of the best. Most anyone can accomplish the install, but if you hire it out it the cost. will depend on the honesty and diligence of the installer. - pianotunaNomad IIISolar is the closest thing to a free lunch you are likely to find. I suggest 400 to 600 watts unless you wish to do an energy audit.
About Travel Trailer Group
44,027 PostsLatest Activity: Apr 19, 2019
