- I have a TST brand TPMS. I went with TST really for no other reason that it comes from the real world of 18 wheeler long haul trucking. Those guys rely on knowing what's going on and that sat well with me.
- smokamotoExplorerIn my limited experience, stay away from Tire Minder model RV-4. Arrived with a dead sensor that took arm wrestling to get a new one.
Then after 1:40 of travel time the sensors started dropping out with “no signal”. Let it sit overnight and then works for another 1:40 (must be a contract thing lol). Again more arm wrestling to get a whole new system. Both of these events required sending the bad parts back - postage paid though.
The new system had the same 1:40 no signal problem. By then I was disappointed, frustrated, and fed up. I bought a TST system which has been flawless for 2 years now!
I’m using the Tire Minder in my 2006 tow vehicle (only has a warning light) which is fine for short trips. But now one sensor is dead, no new battery or re-pairing revived it so I contacted Tire Minder about a new sensor under warranty. Surprise-what I thought was a lifetime warranty is really only 1 year, so into the EWaste it goes. - shelbyfvExplorerI'm happy with the TST. It has a monitor that displays temp and psi for each tire. Easy to take quick looks as part of your normal scanning while driving. You can set parameters for the alarms. I think I'd find a system that relied only on alarms to be less useful.
- msmith1_waExplorerI have a TireMinder brand. The model I have has a phone app so another screen is not required. I have sensors on the truck and trailer. So far I have not had a low pressure situation for it to alert of. It is the only tpms I have used so can't compare it to others.
- QCManNomad IIIFirst thing you need to knw is that any valve stem tpms sensor needs to be mounted on a metal valve stem per the instructions that come with the systems. Next is that you need one that reads when the unit is stationary. Some need to travel a certain distance before the sensors wake up. Last thing you want is to get under way and find out that your tire is low when you are already on the road. The TST systems are a standard for a lot of the trucking industry and are extremely reliable. You will get what you pay for.
- Sandia_ManExplorer IIMost everything we buy for our RV we research and read reviews from Amazon and watch product videos on youtube to narrow down possible selections. No doubt accurate tire pressure and temperature are primary features for any TPMS, equally paramount is consistent connectivity to dedicated monitor or cellphone (via app) from valve stem mounted sensors, some may require a repeater be installed depending on distance from sensors to display.
Most TPMS have the same features, some monitors show tire info incremently while some show all tires at one time. Of course there are the major brands that tend to cost double the price of their less known competitors, whether they perform better and are worth the extra expenditure will be your call. We recently purchased six new 22.5" tires for our class A and picked up a 10 sensor TPMS with repeater on Amazon to monitor our $3K+ investment in rubber and Michelin tires on our toad.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
