RobWNY's avatar
RobWNY
Winterizing question with Antifreeze
I tried the idea of blowing out the lines with air and although it worked to get most of the water out, I could still hear some water gurgling in the lines when the air was being pushed through and thought that I would end up in trouble if there was enough left in any of the lines to accumulate in a low spot so I decided to do the antifreeze method. Everything went fine but when done I had very little antifreeze left and I felt that I didn't get enough in the traps so I bought another gallon. I added it to all of the traps (kitchen sink, bathroom sink, shower drain) and then added some to the toilet. I decided to add some to the black water tank just in case there was some water left in it so I flushed the toilet. There is no trap. Just a drop from the bowl into the black tank. When I flushed, the antifreeze that I pumped into that line came out into the toilet basin as if it was a normal flush, but I didn't have the pump on. Would this be just pressure that remained in the lines after pumping the pink stuff through the system? It stopped spitting out antifreeze within a couple of seconds but now I wonder if I need to pump more antifreeze through the system? Your thoughts and answers are appreciated.
