Kampfirekid
Jul 20, 2020Explorer
Wiring A 30amp RV Outlet - Ground & Neutral
I wired up a 30amp plug in my barn this weekend to power the travel trailer when it’s in the driveway. My barn is wired with a 100amp service breaker cabinet off the house main service, which was installed 18 years ago by a certified electrician, and inspected by the County Building Department.
Question I have is related to ground and the neutral for the plug. The terminations on the plug are done as required,, but at the panel, the ground and neutral bus is bonded together. Is this a no-no for RV services.
I terminated the neutral wire on the neutral buss on the same side as the breaker, and then terminated the ground to the same buss where the ground wire from the house service terminates... which is on the neutral buss on the other side of the panel. Is this correct? Being a single pole 30A breaker, the 120V to the plug is a no-brainer, but is the shared ground/neutral an issue?
Thanks for your help.
