Kalait's avatar
Kalait
Wiring Connection
This weekend my wiring connector became dislodged and has one complete pin missing, several wires were damaged, these have been isolated and the trailer is now parked until proper repairs can be affected! Where can I get a 7 prong female or the wiring harness for the connection from trailer to towing vehicle. :S
  • RoyB's avatar
    RoyB
    Check out ETRAILER.COM
    You will want to purchase a complete new 7-way plug and length of cable molded together. This 7-way cable will plug into your truck 7-way socket.
    ETRAILER will also have the truck side socket if that is what you need.
    They are your best source for all things trailer...
    Roy Ken
  • Any RV parts place will have replacement ends or an entire cord which is about 6 or 7 feet long with the correct end on it. Then it's just a matter of following the cord back to the electrical box behind the trailers tongue and swapping each connection over to the new cord.
    Personally I would replace the whole cord so the end is water proof. It would probably be easier too.
