djgodden's avatar
djgodden
Any special precautions when mounting to edpm roof?
Can you simply drill into an edpm roof or should any precautions be taken? Will the rubber twist on the drill? Getting ready to put I well nuts which will hold my solar panels in place. using 1/4-20x1/2 well nuts.
Thanks,
Joel
  • You can always cut a slip in the membrane, but I think the EPDM is stiff and thick enought that drilling through it won't be an issue.
    I'd also try to get screws into a rafter. Our roof is fiberboard and don't know how well it would hold a well nut with a solar panel that's trying to sail away.
    Thanks,
    Joel
  • MrWizard wrote:
    i anchored mine directly with screws
    but since your going for a bigger hole
    you might want to try a hollow cutter
    a piece of stainless tubing the correct size, sharpened from the inside edge out
    it other words a a round razor turning in your drill driver
    cut the rubber not the under layment
    then use a conventional bit to drill the hole
    this way you don't run the risk of twisting the epdm roof material
    that sort of sounds like what a plug cutter would do. intended to drill plugs out of a board to match the wood used.
    bumpy
  • i anchored mine directly with screws
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
