mleekamp's avatar
mleekamp
Clearance lights on at the campground
I've seen a few TT's and a 5r once in a while with the clearance lights on at night. Nice touch...but how is this mod made? I assume this is not a "factory" deal since I've seen similar trailers to ours this way.
Note: I would have asked the folks that did it but they were out and about when I noticed it...we were at Fort Wilderness.
Thanks in advance for the input.
  • You jump the top two pins on the plug. They are the ones on either side of the raised plug guide.
    Barney
  • The mod is made by inserting a jumper in the plug that connects to the tow vehicle. I don't recall the specific pins to use, but I'm sure someone will be along that does. Please don't leave them on all night though, since they can be annoying to your neighbors. You may also see some that use a flasher to flash the lights instead of having them on steady. That's even more annoying though, so please don't do it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
