DeansDad's avatar
DeansDad
Hunter thermostsat conversion problem
I decided to do the Hunter 42999B conversion on my TT as the Duo-Therm thermostat was like all the others.
I have a Dometic Duo-Therm 13,500 roof air, and I THINK an Attwood furnace (if need be I can remove cover to check).
Here's what I did:
red wire was on Duo-Therm +7.5 terminal, I didn't use it
yellow wire was on Duo-Therm cool terminal, to Y on Hunter
white wire was on Duo-Therm furnace terminal, to W on Hunter
blue wire was on Duo-Therm hi fan terminal, temp not used
orange wire was on Duo-Therm fan terminal, to G on Hunter
green wire was on Duo-Therm gnd terminal, to RC on Hunter
I left the jumper from RC to RW in the Hunter
Also, the small switch is set for HG
I have the furnace working properly, but when trying A/C all I get is the compressor running, no blower fan. Also, there is no fan when the manual fan position is switched on, either.
This seems so simple a conversion, can't believe it's not working right.
  • Good point but the OP said he hears the compressor running so he is past the time delay feature.
  • I had the same problem last summer when I replaced my Duotherm thermostat with a Hunter. What I didn't realize at the time was that new thermostats have a built in delay to protect the compressors during situations where powers will go off and right back on( like during a thunderstorm). It takes 2 1/2 to 3 minutes for the AC to be triggered to come on. Originally, I thought I had a bad thermostat when the AC didn't come on. I took the Hunter back to Lowes and got a second one with the same result. I went to the house disgusted and when I came out an hour later the AC was running. I turned it completely off. I resorted to calling Hunter and the tech politely explained this to me. Embarrassingly, it was on page 25 of the manual. I went back to the trailer, turned it back on and waited a few minutes and it powered right up. Worked normal after that.
  • To the OP- the wiring looks good- try jumping between green and orange to see if you get low fan then. The only oddity is that DuoTherm uses orange to energize the fan and blue to switch between high and low- so even though blue is listed as high fan, you must ground both blue and orange to get high fan.
  • midnightsadie wrote:
    ok I gotta ask, why are people changing the stats?
    Because the analog t-stats over shoot set point by 2-5 degrees
    The swap is to a digital t-stat which controls to set point +-1 degree
    OP.....
    I did the swap without using a mini switch but I wired it to use high fan speed (low fan didn't more enough air for me)
  • Only need to add a switch if you want low and hi air conditioner fan speed. I run mine on low (orange wire connected) and like it just fine that way.
    I don't see anything in your post that reflects incorrect wiring. Perhaps your next step should be to check for voltage on the orange wire.
    Here's a good set of instructions to double check your work: CLICKY FOR HUNTER T-STAT
  • I've run mine without the switch. First on the high fan wire, and then the low fan wire, which I liked better. OP, I don't have the info to help you troubleshoot it, sorry.
  • Did you add the SPST mini switch? You need it in the system to make the AC fan work correctly. AC fan is normal high speed.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
