ewarnerusa
Jan 26, 2015Nomad
I want to install a 12V digital volt meter
I wanted to install a digital LCD volt meter with LED backlight display that I bought off amazon. I'm familiar and comfortable with 12V electrical and I have decided to just tie into a 12V connection from behind the existing control center (where the tank/battery gauges are, water pump switch, water heater switch, etc.). I'm going to mount the volt meter above the control center. While the LED backlight would draw very little juice, I figured I'd want a way to switch it off to avoid any unnecessary parasitic loads. My plan is to wire up a switch that will turn the volt meter display on and off. I snooped around with my multimeter and there are many different wires carrying the 12V signal to choose from. My plan was to pick a favorite and tie the switch into it, then hook the meter to the switch.
Anyone have any comments or suggestions for my idea? Thanks.
