djgodden's avatar
djgodden
Montana Axle Change - Easy or Not?
My 2005 Montana 2955RL has 2 Dexter D52-8 (5,200lb 8 lug) axles. Given it's dry weight of 9,200lbs, this puts them right at the edge. I'm considering changing the axles to either 6k or 7k rated ones.
So... can I simply change the axles and use the same hub/brakes or would those have to be changed as well?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,403 PostsLatest Activity: Apr 09, 2026
