Trackrig
Jan 29, 2016Explorer II
Neat, quick & temporary waste valve repair.
If you have a waste valve leaking and don't want to replace or repair it at the moment, Valterra makes a twist on waste valve that will twist on where you would normally twist on the discharge hose, then you can install the discharge hose on the other side of temporary valve.
I must say that on my MH, a 2005 Fleetwood Excursion, if you install the temporary valve, there wouldn't be any room left to install the hose between the end of the temporary valve and the bottom of the compartment. Having said that, I still think it's a neat item.
In the below Amazon clicky there's a video on replacing waste valves. The twist-on valve is at the very end of the video.
Amazon clicky for twist-on valve.
Bill
Bill
