pbmazda32's avatar
pbmazda32
power inverter install questions
i'm wondering if its possible to buy a large inverter (1500 to 2000w) and tie it into the camper so i can use any outlet i want to. i dont want to wire it so my inverter is powering the charger that charges the batteries. that would just create a loop of wasted power (heat from the inverter)
also, if i have a 2000w inverter running a tv will it use any more power than a 400w inverter running a tv? just wondering if i'll be wasting a bunch of juice.
any help is appreciated or better ideas.
  • mikakuja wrote:
    The charger is the only item that will need to be re-wired. The A/C already has it's own breaker and does not need to be isolated. The fridge is the only other high draw item, and managing it by leaving it on gas works for us...
    There really isn't anything else that's necessary to isolate.
    But it is still necessary to make sure any water heater equipped with a 120 vac heating element has that element turned off. Also, any fridge with a climate control circuit, 'though it is 12 vdc powered, should be turned off as well in order to help eliminate unnecessary drain on precious battery reserve. Unfortunately manufacturers have eliminated this switch on some models, in which case it's advisable to add your own, just as I've done.
  • SoundGuy, Good point on the fridge climate control circut, forgot about that one... We simply pulled the light switch out (shown in your pic) and unplugged the climate control unit then put the switch back in place (ours had 2 separate plugs behind the switch, one for the climate one for the light). As I have no intention in using the climate control I did not add a switch for it.
  • its in and done. everythings working as it should. found and marked the breaker for the AC. Theyre was a small breaker all the way to the right, flipped it and the charger shut off. so i can flip that off, turn the fridge to gas and im good to go. like i said earlier, my hot water tank is gas only so no need to worry about that. coffee pot ran fine, as did the battery charger for my tools. transfer switch in the inverter worked perfectly. had the inverter running with the tv and roku on, fired up the genny and it flipped over without a blip in anything. thanks for everyones help, its really appreciated.
  • is this the right product?
    https://www.amazon.com/RV750ULHW-Inverter-Charger-Hardwire-Output/dp/B000FTH2R0/ref=pd_sbs_107_t_2?_encoding=UTF8&psc=1&refRID=VRVVZ2D0ES20A5Y5MNER
    I'm not positive, but I don't think you want this. If you plan to replace your existing converter/charger, it can be wired to give you the 120 vac you're looking for, but I don't believe this will provide the 12 vdc output you have now. You will have to keep your existing 12 vdc in tact.
    I did what you are planning with a 600 watt PSW Xantrex. I just plugged my rv input into the inverter and opened the breaker for the charger. I had 4-6 volt golf cart batteries, so it would last several hours if I was careful about how many lights, tv's, Directv receivers, etc. I used at a time.
    Sorry my post didn't make much sense. i forgot to quote the post (on top) i was referring to.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
