lawrosa's avatar
lawrosa
Second battery doesn't pull amps but I can push 70+ amps
So I did a mode to my truck for a third source of charging. I know the guys will say its inefficient and ill blow up my alternator etc etc..
The camper package battery has a fuse behind the batt. Impossible to get to without removing battery..This battery powers the 7 pin and has an isolator. I can leave the truck plugged in all night to parallel with my other two batts on trailer.
So I removed the 40 amp fuse and replaces with 100 amp breaker
So with dead batts on the camper I can push 16 amps or so through the 7 pin. But hardly nothing pulling while dry camping. It seems it pulls 95% from the camper batts first, especially at high draw.
So I made this mod with 6 gauge direct off aux battery
Upon a few tests with 6 gauge wire and a andreson plug tied to the 40 amp mega fuse, the fuse would blow.
I had an extra 100 amp breaker so I removed the mega fuse and replaced it with this set up.
I can now parrellel my RV batts with the truck with this 100 amp 6 gauge set up.
Running a 70 amp load off inverter and with truck running, the truck supplied the whole 70 amps. This is fine. Im happy with this set up but,,,,,
I know ohms law comes to play here. When im plugged into the TT and all 3 batts are parrellel the truck batt still seems to not pull the amps as the two camper batts. ( with truck off)
Example if im pulling 20 amps from TT batts I may only be drawing 2-3 amps from truck batts.
Is there anyway to correct this? I can push fine but cant pull very well.
I have a similar connection on the TT batts side. I connect this when dry camping. ( as seen in short vid)
Its about 11 ft of 6 gauge winch cable.
Just a side note possibly the isolator is faulty? I wouldn't think so if it pushes amps properly. It would work both ways I assume. Also it is a GRP 78 - 70 AH batt. Ratted at the 20AH rating per exide
Short video.
Charging off alternator
Pics
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
