thebat68's avatar
thebat68
Upgrade to 50amp - now AC doesn't work
Okay, so a few weeks ago went out to the TT to get it ready for a trip and my AC had died. I replaced with a new Dometic Brisk II and it seemed to working great at home.
I had planned a 50amp upgrade from my 30 and did that yesterday. Everything seems to work, except that the AC doesn't kick on. Now, I'm only plugged into my house 20 amp circuit, but the AC always worked before on it with no issues.
Is there some reason with the way that 50amp service works that my AC shouldn't work - is it somehow getting much less amperage?
I have double-checked all the connections in the circuit box and everything is tight - even put a meter on the breaker to make sure it wasn't bad.
I don't have a 50 or 30 amp source readily available to try, which is why I'm normally just plugged into the house wiring.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Feb 21, 2026
