- kennethwoosterExplorerI like 6 but nothing wrong with 7.
- NorskemanExplorer
Atom Ant wrote:
Norskeman wrote:
That is something I never plan for, at least at 75mph! :B
if the trailer and tow vehicle are going off-road then this needs to be 8” to 10”.
4X4 with a fifth wheel - professional driver on a closed course - do not try this at home. - Cummins12V98Explorer III
Norskeman wrote:
Per my Husky hitch manual - The amount of clearance between the top of the pickup box and the underneath of the trailer. At a minimum this should be 6”, if the trailer and tow vehicle are going off-road then this needs to be 8” to 10”.
Does it mention how many "stacked fists" for off road clearance???? - BlackcellExplorerA rule thumb is minimum of 6" but I've got away with just 5" but that was with a previous light fiver pin weight. I now have 8-9" but still gotta watch some of those entry/exit parking dips especially at some fuel stations.
- Scott_sExplorerThanks for the help everyone. The gooseneck was done by the previous owner. I had a b&w gooseneck for my work trailers so it worked out. My truck is used for work and I have to have a flat bed when not using the 5er. I may switch it back to FW by using the B&W FW that attaches to the gooseneck ball. Not sure it's really worth it though because the old owner pulled it a lot as goose nek so if there is any damage it's already been done. The trailer is a 2004 coachman and its in great shape so I don't thing th GN set up has harmed it any. Right now it has 7 in of clearance and is almost dead level. We are going on a 1000 mile trip next week so I will keep a close eye one it . Thanks again for the replies
- Atom_AntExplorer
if the trailer and tow vehicle are going off-road then this needs to be 8” to 10”. - NorskemanExplorerPer my Husky hitch manual - The amount of clearance between the top of the pickup box and the underneath of the trailer. At a minimum this should be 6”, if the trailer and tow vehicle are going off-road then this needs to be 8” to 10”.
- OaklevelExplorerIs the trailer level at 7" if so your fine..... If not you need to be careful that you are not overloading the lower end trailer axle. Trailer should be close to level hitched up.
As above gooseneck adapters are not necessarily recommended on a fifth wheel trailer puts more stress on the frame as they are not designed like a gooseneck trailer. - Cummins12V98Explorer III
Atom Ant wrote:
"Two stacked fists" is what my tech told me once :B
7" should be fine. Just watch how it does in the dips out of a parking lot. If the bed gets too close to the bottom of the trailer you may need to raise it.
I love those type of directions. Who's fists?
6" minimum. - Atom_AntExplorer"Two stacked fists" is what my tech told me once :B
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
