- memtbExplorerI don’t see an issue with fabricating a rack......assuming that you have sufficient frame integrity and the weight will not adversely effect your pin/tongue weight.
All of that said......if I have a choice, I would never go propane. Been there - done that ! As compared to gasoline .....propane is very inefficient! You will use much more propane to accomplish the same job. PLUS - gasoline is quite accessible and is a quick/easy fill.....propane - not so much! JMO! memtb - AllworthExplorer IIPropane on the rear rack may not be DOT legal!
- LwiddisNomad IIIConsider extra lights for the rack.
- valhalla360NavigatorAs long as it's relatively light generator and you beef up the rack (welding directly to the frame), should be fine.
Yes it will impact the pin weight but 5ers start with a much higher percentage on the pin compared to bumper pull and with the wheels further back, each pound in the rear takes less weight off the pin. - laknoxNomad
Duke-44 wrote:
I already have a rear rack on my fiver and my power inlet is there, too. Is there any problem with installing the propane generator and propane tanks there?
If you =do= do this, install in a "gen box" to cover everything up and give it at least a little disguise. One YT couple had a Champion 3k stolen right off their cargo rack in downtown Denver rush hour traffic. Got in a hurry and forgot to put the cable lock on it; scumbags just cut the ratchet straps.
Lyle - theoldwizard1Explorer IIGet a good, experienced welder to build that rack.
It will lighten the pin weight. - stickdogExplorerOnly if someone rearends you.
I csrry my 2 3000 generators
2 5gal gas cans and 2 5 gal diesel cans.
I figure I'm far enough a hhead of the boom.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
