The vehicle manufactures tire pressure is just a recommendation only and is not the correct pressure for every and all load situations.
The tire placard says to see your vehicle mfg manual....the vehicle manual says to see the tire dealer/manufacturer which RV .net members have done for years.
Tire placard ??
Here's what NHTSA says about it and notice it says to consult the tire dealer if any doubt.
NHTSA homepage
TIRE SAFETY
Everything Rides On It
Tire Size
To maintain tire safety, purchase new tires that are the same size as the vehicle's original tires or another size recommended by the manufacturer. Look at the tire information placard, the owner's manual, or the sidewall of the tire you are replacing to find this information. If you have any doubt about the correct size to choose, consult with the tire dealer.
And from safecar.gov; NOTE; the words recommended. Nowhere is does it say its some kind of law or the boogy man (DOT or a lawsuit nonsense) will get you if you don't use what it says.
Frequently Asked Questions (FAQs)
1. What is a tire “placard?” And where is it usually located?
A tire placard is really just a fancy name for a tire information label. This label contains several key pieces of information: (1) the vehicle manufacturer’s recommended psi (pounds per square inch) or kilopascals (kPa) of air pressure for your vehicle’s tires, (2) the maximum weight (or “load”) you should have in your vehicle. Load or weight limits are usually given in terms of number of occupants or total weight (in pounds or kilograms) and (3) the recommended tire size."
When trying to make a point copy and paste your point as some of these documents are pages long with info that is mostly irrelevant information to the topic. A clicky is optional.
