outlaw85
May 11, 2016Explorer
The Camper Saga. Opened a can of worms or mice..
This is a continuation from my other post about locating the drain plug. Long story short- there was a mouse problem.
1997 Damon Challenger 30RK
While flushing the water I found-
-A hole in the fill neck from the potable fill port to the tank
-Some wires with insulation chewed off (not broken) in the same spot
-A leak somewhere in the sub-floor under furnace / duct work
Not sure if I should cut losses or keep trudging along. I've already removed the 'debris plate?' underneath and could not see any of the water lines. At this point, I can only see removing the furnace to cut a hole under it so I don't have to do visible damage.
I'm new to camper owning and doing the best I can. I don't have the funds to send it to the shop for them to rebuild it (assuming this is what would happen). If it were to go to the shop, I'd probably be better off selling/trading it in.
Any recommendations or suggestions are greatly appreciated.
Outlaw
Outlaw
