Rich_Mar's avatar
Rich_Mar
tire pressure
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an reluctant to inflate to 80 psi and go on the road when it's 90% out. Then it becomes a guessing game, what psi at 90, at 75, at 45 degrees. 8200lb 5er. The sidewall does read, max pressure, so should you put less due to the temp? Or let the pressure go well over the 80 because of the heat?
