AllegroD wrote:
J-Rooster wrote:
rgatijnet1 wrote:
On a single 120 volt outlet I have been able to run one AC as well as the TV and lights. I switch off the AC when using the microwave.
The WH is on propane as is the refrigerator.
It just requires energy management and watching the meter to see how many amps you are drawing.
X-2, I've done this before Brian, but you don't want to do this in extreme heat!
If you do this and do not have an PI EMS that shuts down current at 104v, I suggest you get a Kill-A-Watt and plug it in. Of course you will want to check occasionally. If current drops to 104V, turn off the A/C. If you let the A/C run at 104 or below, you will start incurring heat damage and shorten the life.
I do have the PI EMS but I believes it shuts down the power when it drops to 108 volts. If a 120 volt outlet is wired properly, you should be able to draw the maximum amount of amps without any significant voltage drop, just like any outlet in your home. If you have to run a long extension cord to the 120 volt outlet, then you may have a voltage drop. Just using your large 50 amp RV cord, and the adapters, hooked up to a properly wired 120 volt outlet, should be fine without a significant voltage drop altho it is not a bad idea to monitor it to insure that it was wired with the correct gauge wire.
