liberty2010
Aug 27, 2013Explorer
see if you can determine what other plugs are on that breaker. When the breaker is off check plugs with a lamp or some corded tool. that might show you it is some other device that is bad. if not it sounds like a wire has rubbed through to ground or a screw might be into the line shorting it. good luck
38,707 PostsLatest Activity: Feb 20, 2025
