Heisenberg
Aug 27, 2013Explorer
If you know how you need to lift the wire off the breaker. If it will not reset swap the breaker out with a new one. If it will reset you need to inspect the outlets on that circuit first for a short until you clear it. If it is in the romex/cable it will be difficult, but not impossible, to isolate. You just have to break the circuit at each outlet until the trip clears.
38,707 PostsLatest Activity: Feb 20, 2025
