TROPYEK's avatar
TROPYEK
2008 allegro bus leveling post have to replace
landing ear bent on passenger side bent have to replace, is there any precautions I have to take or is ot something I should bring to repair shop, I am pretty handy, but not sure about pressures involved if any.
  • These are electric legs I replaced leg, easy to replace plugged everything back in rear leg would not go up unplugged and switched to other leg in back something happened followed all instruction to reboot nothing works jut saw switch on diagram maybe this is our problem. Thanks for your help John
  • azpete wrote:
    the pads get bent when the jack slips off the block under it. if your system is hwh, the foot is replacable.
    part is available thru hwh. look up ap part number of jack in the parts manual. foot is listed as a separate part.
    It cannot slip off unless the bottom "TIT" on the bottom of the piston has sheared off. When you have a HWH jack pad that has slipped, it will shear this "TIT" off. If so, you need to replace the complete cylinder. Without that "TIT" thru the center of the foot it will slide off again. IF BOLTED it cannot slip. If you are talking about slipping off a WOOD shim block, then forget this post. Doug
  • the pads get bent when the jack slips off the block under it. if your system is hwh, the foot is replacable.
  • 2008 can have Atwood electric or HWH hydraulic jacks. If HWH no pressure involved when retracted. It takes upper body strength to release the 2 springs on HWH from the mount holes. 2008 may have the pads bolted or not as HWH changed the design around that time. If also bolted, once the springs are removed you just unbolt the nut in the bottom center of the pad. Atwood, I have never seen a bent pad, so I do not know if they are replaceable. Doug
  • Type of levelers?:h Depending on the brand, usually once the pressure is released, it's simply a matter of mechanical work. That said, regardless of mfg. be sure to block the coach before attempting repairs...Dennis
    Please see my response HERE
