- Dutch_12078Explorer III
2cAmerica wrote:
To Dutch 12078'
Off, unplugg, flip coach breakers, plug shore line, flip park breaker on.
Thanks... I suspect the park breaker was the culprit then. - 2cAmericaExplorerTo Dutch 12078'
Off, unplugg, flip coach breakers, plug shore line, flip park breaker on. - Dutch_12078Explorer IIIDid you flip the park breaker off before unplugging and then back on after plugging in again?
- 2cAmericaExplorerContacted Fleetwood Customer Service and a quick solution was: unplugged the shore line at source, then plugged back in. Magic, worked. Appears on one half of 50amp connected. DW very happy.
- IvylogExplorer IIIWas it one of the two 120V breakers on your inverter?
- BusskipperExplorer
Dutch_12078 wrote:
If it's not the inverter, trying turning the circuit breaker on the post off and back on. You may only be getting power on one of the two hot legs. Both sides are supposed to trip if one does, but I have seen instances of that not happening. Another possibility is a problem with the transfer switch with one leg not making contact on the shorepower side when the generator is off, but connecting to the generator when it's running.
Sounds like the issue - see if you can change site or plug in through your 30 amp convertor - that might work - if not on 30 then most likely the inverter is the issue.
Let us know how you solved the problem.
BOL, - imgoin4itExplorerHad the same thing happen once and for what ever reason the electric pedistal had the problem. I checked it and only had power on one leg. Moved to next site and problem gone.
- Dutch_12078Explorer IIIIf it's not the inverter, trying turning the circuit breaker on the post off and back on. You may only be getting power on one of the two hot legs. Both sides are supposed to trip if one does, but I have seen instances of that not happening. Another possibility is a problem with the transfer switch with one leg not making contact on the shorepower side when the generator is off, but connecting to the generator when it's running.
- Ranger_SmithExplorerIs that an outlet that works off the inverter and maybe is the inverter breaker tripped.
38,778 PostsLatest Activity: Jun 10, 2026
