bigcritter
Jul 08, 2013Explorer
Adding additional outlets to inverter
I have a Xantrex 1000-watt inverter in my MH, with only certain outlets connected to the inverter throughout the coach. I have gone through the coach with my voltage meter to determine which outlets are HOT when there's no shore power and the inverter is turned on. However, the main outlet in the bedroom is NOT wired to the inverter, although the TV is, but it makes it very difficult running our CPAP machines on the inverter without use of multiple extension cords. NOT an ideal situation. Our CPAPs require an expensive 12 volt plug, according to the manufacturer, so the inverter is the best option. What I would like to somehow do, is connect an existing outlet to the inverter circuit, OR.....wire a separate outlet directly to the inverter strickly for CPAP use when not connected to shore power. Anyone have any experience or expertise in doing something like this? Just how difficult would it be? Please......I'm NOT asking for all the other alternatives to doing this, I'm simply asking HOW to do THIS. :)
Thanks in advance!!
Thanks in advance!!
