Jim
May 04, 2016Explorer
Air Actuated Step Cover
My air actuated step cover stopped working on a recent trip. It's stuck in the 'open' position so that makes it easy to work with but I would like to get it working again.
Here's what it looks like:
When I took the cover plate off, I found that the hose assembly (two small air hoses coupled together into a single coupling) had uncoupled from the actuator knob. I can't see anything broken, and it all snapped back into place easily enough, and it feels like it did before...but, it still doesn't work!
I started the engine and got the air pressure up to normal, but...nothing. Also, when I switch to 'Open'? Before, it would just easily pull out from its hidey hole. Now, it's resisting my efforts to pull it out.
I can't seem to find a Winnie drawing of the air system, and I'm hoping someone else has had this problem and came up with a solution.
Thanks for any help or insight!
