David0725's avatar
David0725
Explorer II
May 29, 2023
Awning not working right
Hi I have new to me DS 2005 with a weather pro awning that wasn't working right when I bought the RV. I just now had time to mess with it and it's opens but gets stuck 2 or 3 times going out and comin back in. I have to let it sit for a few minutes then push the button again it will move a few feet then stop. Any idea what's going on? Thank you
  • Weatherpro awning that has your symptoms indicates a bad motor. It is tripping the excess amp control. To manually retract, you disconnect the motor wire plug from the controller and apply 12 volts to the 2 wires. If the controller is not easy to find, you can also disconnect the quick connect at the motor and jump the 2 motor wires with a 12 volt battery. I use a 12 volt Computer battery back up(UPS) battery to do this. Doug
    PS, there are 2 motors the Weatherpro uses. Depends on if you have the intergrated roll down patio screen as part of the awning assbly. Roll out the awning and get the Model/Spec/serial number before it finally fails.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If that unit works the way I think it does (I had one) the controller is current sensitive.. That means you press the button and the motor starts to trun. when the motor suddenly draws more current (indicating it's not turning) the unit shuts off.
    Something may be overloading the motor.. first step is to inspect the awning to insure it's rolling and unrolling smoothly.. also check the gas shocks to insure they are not binding.. finally Lubricate.
