peterman1
Mar 23, 2015Explorer
cant identify my steps please help
hi everyone
I have a fourwinds hurricane 2008 3 slides its also a 34b model. well my steps have had it. I pulled the motor and gear box off and found two broken teeth on the big gear in the gear box also tested the connection that plugs into the motor and I get 13 volts for about 5 to 10 seconds when opening and closing the door. I then plugged in the motor just to test but it did not work. I then banged on the motor on the concrete a few times then it started to work for about 3 cycles then it went dead again. im going to replace the gear box and motor but I cant find any stickers or numbers anywhere. does anyone know of a way I can identify what model steps I have..
