chucl66's avatar
chucl66
Damon Intruder,2000 lr/dr, slide won't go out.
I am unable to put slide out. The switch gets power with the in pushed, but nothing when out is pushed. I have bypassed the switch.
has power to in side , none on out.
Have checked all fuses in main fuse panel, all are hot.
Is there something I am missing.
Thanks, Chuck
PROBLEM SOLVED.
Thanks again,
Chuck
  • Problem solved.
    Found loose wire near motor.
    Thanks for all the post.
    Chuck
  • I had a slide switch that was doing the same way. I found out by pushing in the switch slowly it would come to a certain point and work. I did this until I bought a new one. You might also try spraying switch with contact cleaner.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Switch is the problem. Here is a procedure that MIGHT fix it.
    REMOVE all 12 volt power. You do not want power to the switch,, Easiest way to do this is "DISCONNECT (Store mode) and disconnect.
    Operate switch like 50 times.
    Restore power.
    NOTE: I can not guarantee this will work (The problem could be in the wires or the module) but if it does not work your FREE is hearby cheerfully refunded.
    And if it does work.. The charge is a post reporting same.
  • Is your emergency brake set? I use to own a 2000 Damon Intruder, and if I remember right the emergency brake had to be set, and the slide will not work if the engine running.
