- LakeNExplorerWhy not use a clear fitting + standard sewer hose so u can see the output? Make a decision later.
- vic46ExplorerThe macerator is a poop processor. There are two intents. First no clogged sewer hoses (full size) and second, no poop mountain. The second intent is best served with the use of lots of water.
- StutchExplorerLOL.... That's what I was afraid of. What's the point of macerating toilets if you still have to use a 3" hose. My understanding is that the macerator pulverizes to a point where the result is basically dirty liquid. Nothing big enough to clog.
You are right... The last thing I want to do is have to disconnect this hose if things aren't flowing! - BumpyroadExplorercan you find something at home depot, etc., that is smaller than a stinky slinky but larger than a garden hose? most of the advantage of a macerating setup is not using a stinky slinky.
I drained my black tank with a sewer solution and a macerator pump thru a 3/4 " or thereabouts hose that came with the SS so don't know why that wouldn't work unless macerating toilets don't work as well?
bumpy - vic46ExplorerNot something I would be trusting. Clearing a clogged a 3/4 inch hose that is clogged with effluent would be something I would avoid like the plague! I would use a standard size sewer hose and not risk a clog.
- StutchExplorerDrain outflow? The cap is a standard 3" cap with a male fitting that is for a standard garden hose. I believe it is designed for allowing the Gray Tank to be left open.
I purchased the campsite sewer adapter from Cleandump. It has a 3/4" adapter. So, I think I am asking... will gravity allow a macerated black tank to flow through a 3/4" hose. - vic46ExplorerWhat size is the drain outflow?
38,766 PostsLatest Activity: Jan 10, 2026
