JaxDad wrote:
A heat pump works by taking heat from the air in one place and moving it to another. Thus the term “pump”.
You cannot with a heat transfer pump take heat from a single space and put it back in the same space and end up warmer than before. Extra heat requires extra BTU’s, period.
If your unit is making heat without an external source of BTU’s it is from the parasitic (friction) losses of the pump and motor running.
The only concepts I can grasp are facts and science.
Magic and hokus-pokus are beyond me.
Portable heat pump/AC units have been produced and sold for decades with many happy buyers. Perhaps you should read how a single hose heat pump works. Be sure that you don't get confused between AC and heat pump operation.
As far as the brand of mine. It is an Spt but all single and double hose portable heat pump/AC units work the same way, except a double hose unit uses outside air.
My heat pump, with the single hose draws ambient air from the RV cabin. Some of that air is passed over the condensing coil, heated, and blown back out in to the RV. Some of the air taken in, BUT NOT ALL OF IT, is blown back out over the evaporating coil and is expelled to the outside, thus completing the entire refrigeration process.
My unit must have an INSIDE temperature of 45 degrees or higher to be able to function as a heat pump, since that is the only air it uses. At anything over 45 degrees, it will start warming the area as soon as you turn it on. If it warms the area to 95 degrees, then it stops working efficiently. We usually keep the inside of our RV at 65 in the Winter so the air being used by the heat pump is 65 degrees, regardless of the outside temperature.
