Berner2
Oct 14, 2013Explorer
Flooring, laminate or wood?
I am getting ready to replace the carpet and linoleum in my MH. I am leaning towards wood, but, I thought I'd check here to see what others have done and if you're happy with your choice.
Did you use wood or laminate and if you were doing it again would you use the same material? Why or why not?
Did you install it length wise or side to side and if so did you install at an angle other than 90*
I believe I've seen wood installed at a 30* or 45* angle.
Did you cover the floor in your slide or leave it carpeted?
Glue/nail or floating?
I know there are several questions here, but, I would appreciate your input.
Thanks
Thanks
